TwinTurbo.NET: Nissan 300ZX forum - Re-check the screws on the intake VCs as well...the
jzack
on February 14, 2010 at 1:25 PM
Post Plenum Pull need help lost all my oil driving 20 miles
posted by wolftg
on February 14, 2010 at 10:44 AM
new gaskets there will compress a bit and the bolts need to be re-checked. Even more so if you also replaced the nylon washers that fit under the heads of those screws...
wolftg
10:44:02 02/14/10
First I would use RTV that has the highest heat and >>
ZUL8TR
11:28:07 02/14/10
Re: Post Plenum Pull need help lost all my oil driving 20 miles
ali300zx
12:15:50 02/14/10
2 different leaks
wolftg
13:05:18 02/14/10
i learned the hard way as well that surfaces don't only
KasbeKZ(VA)
13:09:39 02/14/10
Re-check the screws on the intake VCs as well...the -
jzack
13:25:59 02/14/10
Zxpress
19:49:02 02/14/10
out of curosity, how bad was the valve cover leak? (n/m)
SuparexTT
12:06:09 02/19/10
